Rob-xr500
Apr 12, 2021Tutor
Xr500, I have an issue with my Nat type on call of duty.
Looking for help with Moderate NAT type on call of duty warzone, i am having issue with joining friends private chats and finding games when the party leader. My setup is Sky home hub connected to ...
Apr 12, 2021Guru - Experienced User
Have you tried putting the xr500 into the sky hub's dmz?
- Rob-xr500Apr 12, 2021TutorNo havenât tried that. Just put xr500 WAN IP into dmz on the sky router?
Will try that in the morning will let you know how it goes. Thanks for the reply đ - Rob-xr500Apr 12, 2021TutorHi just tried it still have moderate NAT type đ©
- plemansApr 12, 2021Guru - Experienced User
you might need a reboot after changing it.
you can also check through the dumaos optimal settings guide
- Rob-xr500Apr 13, 2021Tutor
Morning, managed to get the NAT type to stay open when connecting over wifi but as soon as i connect with cat8 ethernet from the xr500 to the playstation NAT type changes to moderate again?
