Rob-xr500
Apr 12, 2021Tutor
Xr500, I have an issue with my Nat type on call of duty.
Looking for help with Moderate NAT type on call of duty warzone, i am having issue with joining friends private chats and finding games when the party leader. My setup is Sky home hub connected to ...
Apr 12, 2021Guru - Experienced User
Have you tried putting the xr500 into the sky hub's dmz?
Rob-xr500
Apr 12, 2021Tutor
Hi just tried it still have moderate NAT type đ©
- plemansApr 12, 2021Guru - Experienced User
you might need a reboot after changing it.
you can also check through the dumaos optimal settings guide
- Rob-xr500Apr 13, 2021Tutor
Morning, managed to get the NAT type to stay open when connecting over wifi but as soon as i connect with cat8 ethernet from the xr500 to the playstation NAT type changes to moderate again?
- antinodeApr 13, 2021Guru
> [...] managed to get the NAT type to stay open when connecting over
> wifi [...]"managed" _how_?
> [...] as soon as i connect with cat8 ethernet from the xr500 to the
> playstation NAT type changes to moderate again?Did however you "managed" the success involve the IP address of the
Playstation?Did the IP address of the Playstation change when you connected it
using a different interface?
