michaelbeard99
Mar 04, 2021Aspirant
XR500 in a lan to lan configuration - how to get the ntp working?
In order to get a few devices, eg printers, to work across the house, i set my XR500 up in a lan to lan configuation with the ISP modem/router. Modem/router is at 192.168.1.1, and XR500 is at 192.168...
antinode
Mar 04, 2021Guru
> [...] i set my XR500 up in a lan to lan configuation with the ISP
> modem/router. [...]
Have you considered the potential advantages of using the documented
method of configuring the XR500 as a wireless access point, instead of
your ad hoc "lan to lan configuation"?
> Any ideas would be very much appreaciated!
You might start with an oft-neglected resource:
https://en.wikipedia.org/wiki/RTFM
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual (at least). Read. Look for
"Use the Router as a WiFi Access Point Only".
- michaelbeard99Mar 05, 2021Aspirant
ah, I'll take a look at that, thanks! I have some ethernet connections at the XR500 as well; does making it an AP no longer permit the use of the ports?
- michaelkenwardMar 05, 2021Guru - Experienced User
Disabled Features on the Router when set to AP Mode | Answer | NETGEAR Support
The XR500 is an expensive "gaming router" with many added features that would doubtless disappear in AP mode.
Only you know if those features are important to you.
The ports would work, but probably not much else.
Let me try that again, thanks..
