michaelbeard99
Mar 04, 2021Aspirant
XR500 in a lan to lan configuration - how to get the ntp working?
In order to get a few devices, eg printers, to work across the house, i set my XR500 up in a lan to lan configuation with the ISP modem/router. Modem/router is at 192.168.1.1, and XR500 is at 192.168...
michaelkenward
Mar 05, 2021Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so you might get responses here, but you might get more help, and find earlier questions and answers specific to your hardware, in the appropriate section for your device. That's probably here:
Nighthawk Pro Gaming Routers - NETGEAR Communities
This is especially important for these devices as they run with DumaOS rather than the standard Netgear firmware. The DumaOS people are very active in that section and can probably respond more quickly.
I will ask the Netgear moderator to move your message.
