michaelbeard99
Mar 04, 2021Aspirant
XR500 in a lan to lan configuration - how to get the ntp working?
In order to get a few devices, eg printers, to work across the house, i set my XR500 up in a lan to lan configuation with the ISP modem/router. Modem/router is at 192.168.1.1, and XR500 is at 192.168...
Netduma-Liam
Mar 05, 2021NetDuma Partner
You can configure NTP settings in Settings -> Administration -> NTP Settings.
I'm not sure if it will work, but you could try settings the ISP modem as your NTP server?
Alternatively, you could just use the default Netgear NTP server?
- michaelbeard99Mar 05, 2021Aspirant
many thanks- I can only get that to work when the XR500 is plugged into my modem/router though its WAN port.
