UnknownSith
Nov 02, 2018Apprentice
XR500 in game disconnect
Hi, I have an XR500 with a wired connection to a PS4 pro. The problem is that during gameplay on black ops 4 I keep getting a connection interrupted error! It doesn’t kick me from the game it just lea...
Maniac007
Jan 14, 2019Aspirant
Same problem !
And... It works perfectly with my poor dlink :/
Netduma-Fraser
Jan 15, 2019NetDuma Partner
What does the Geo-Filter ping of the game show when this happens? Is QoS being used?
- lincoln_echoJan 15, 2019GuideI turned off qos works great now no interruptions
- Netduma-FraserJan 16, 2019NetDuma PartnerI doubt QoS would be causing this. Likely just a coincidence that it's been resolved since disabling it and I wouldn't recommend disabling it otherwise your devices may cause you lag
- lincoln_echoJan 16, 2019GuideNo lag here and we are gamers with two ps4 had it this way for a month now
