UnknownSith
Nov 02, 2018Apprentice
XR500 in game disconnect
Hi, I have an XR500 with a wired connection to a PS4 pro. The problem is that during gameplay on black ops 4 I keep getting a connection interrupted error! It doesn’t kick me from the game it just lea...
Netduma-Fraser
Jan 15, 2019NetDuma Partner
What does the Geo-Filter ping of the game show when this happens? Is QoS being used?
lincoln_echo
Jan 15, 2019Guide
I turned off qos works great now no interruptions
- Netduma-FraserJan 16, 2019NetDuma PartnerI doubt QoS would be causing this. Likely just a coincidence that it's been resolved since disabling it and I wouldn't recommend disabling it otherwise your devices may cause you lag
- lincoln_echoJan 16, 2019GuideNo lag here and we are gamers with two ps4 had it this way for a month now
- Netduma-FraserJan 16, 2019NetDuma PartnerIf it works for you then that's great but QoS unlikely to cause lag as it's purpose is to prevent it, was probably an update on the game side around the same time
