UnknownSith
Nov 02, 2018Apprentice
XR500 in game disconnect
Hi, I have an XR500 with a wired connection to a PS4 pro. The problem is that during gameplay on black ops 4 I keep getting a connection interrupted error! It doesn’t kick me from the game it just lea...
dcontroller
Mar 14, 2019Aspirant
I typically only play BO4 and have not tried to disable the Geo Filter yet. Will try both and let you know. But if the Geo Filter is the case does that not make part of the reason of buying this router a bad decision? Surely you should be able to use the Geo Filter on this router without there being an issue.
Netduma-Fraser
Mar 14, 2019NetDuma Partner
Okay keep us updated. I'm just trying to eliminate possible variables to determine the underlying cause of the issue, it may not be the Geo-Filter at all. If it's the Geo-Filter then it could be your Geo-Filter Settings causing the issue e.g. too restrictive or could indicate we need to do something on the cloud.
