usermac
Jan 25, 2019Luminary
XR500 inaccessible cumulative update bug
I am quite surprised there is no mention of this bug on this forum but if you reinstall your windows 10 or download cumulative update KB4480116 or onwards you will not be able to acess local IP adres...
Netduma-Fraser
Jan 25, 2019NetDuma Partner
That's very odd, doesn't sound like a router issue though. If you disable your PC firewall can you connect? Also can you connect using routerlogin.net?
- usermacJan 25, 2019Luminary
Nothing works for me I have tried firewal aswell the update broke acess to all local ip adresses.
see this link this is my problem
https://borncity.com/win/2019/01/18/windows-10-network-bug-in-all-versions-fix-are-planned/
In the mean time no acess to XR500 not good at all as the solution that microsft offer as a fix does not work at least for me it does not.
- Netduma-FraserJan 25, 2019NetDuma PartnerSet a static IP on the PC and then try then
So far the static IP trick did the job so thank you
