usermac
Jan 25, 2019Luminary
XR500 inaccessible cumulative update bug
I am quite surprised there is no mention of this bug on this forum but if you reinstall your windows 10 or download cumulative update KB4480116 or onwards you will not be able to acess local IP adres...
usermac
Nothing works for me I have tried firewal aswell the update broke acess to all local ip adresses.
see this link this is my problem
https://borncity.com/win/2019/01/18/windows-10-network-bug-in-all-versions-fix-are-planned/
In the mean time no acess to XR500 not good at all as the solution that microsft offer as a fix does not work at least for me it does not.
Netduma-Fraser
Jan 25, 2019NetDuma Partner
Set a static IP on the PC and then try then
- usermacJan 25, 2019Luminary
So far the static IP trick did the job so thank you
- Netduma-FraserJan 25, 2019NetDuma PartnerGreat to hear that!
- usermacJan 25, 2019LuminaryThanks again always a quick response đ
