Username5
May 27, 2018Tutor
Xr500 include high ping filter?
The netduma used to have a filter for high/laggy ping players. Does this version of DumaOS still include it aside from the Geofilter?
Netduma-Fraser
May 27, 2018NetDuma Partner
Are you referring to ping assist? If so that would still only get you a server under your ping limit, not block players from joining the server. That will be coming.
If you're referring to Deny & Allow then yes that is present on the XR500.
- Username5May 27, 2018TutorThank you. My main concern before buying is for example..
Intentionally laggy player joins destiny game...
Destiny compensates all other players and makes it a terrible game.
Not certain they do this but seems likely with how inconsistent the game is.
So I would want to filter all bad pings.- Netduma-FraserMay 27, 2018NetDuma PartnerDestiny uses a hybrid system so you could block those players but they may then connect to a server that you connect to. Though as you're closer to the server you have the advantage.
- Username5May 27, 2018TutorOk thank you. I don't really understand all of it but I had the original netduma and Destiny was so bad I couldn't get into a game when putting in even extremely mild restrictions. I really like what you guys are doing though and hope it eventually forces cheap/lazy devs like Bungie to make different decisions.
We just got Gigabit internet a few days ago and I am happy to see your software on a router I can use!
I will buy the router on my way home if best buy is still open. I hope you continue your work and wish you the best.
Thank you for the answers also.
