Username5
May 27, 2018Tutor
Xr500 include high ping filter?
The netduma used to have a filter for high/laggy ping players. Does this version of DumaOS still include it aside from the Geofilter?
Username5
May 27, 2018Tutor
Thank you. My main concern before buying is for example..
Intentionally laggy player joins destiny game...
Destiny compensates all other players and makes it a terrible game.
Not certain they do this but seems likely with how inconsistent the game is.
So I would want to filter all bad pings.
Netduma-Fraser
May 27, 2018NetDuma Partner
Destiny uses a hybrid system so you could block those players but they may then connect to a server that you connect to. Though as you're closer to the server you have the advantage.
- Username5May 27, 2018TutorOk thank you. I don't really understand all of it but I had the original netduma and Destiny was so bad I couldn't get into a game when putting in even extremely mild restrictions. I really like what you guys are doing though and hope it eventually forces cheap/lazy devs like Bungie to make different decisions.
We just got Gigabit internet a few days ago and I am happy to see your software on a router I can use!
I will buy the router on my way home if best buy is still open. I hope you continue your work and wish you the best.
Thank you for the answers also.
