GoldenSifter
Aug 03, 2020Follower
XR500 Initial SpeedTest retest
Hello everyone, So when i did the inital setup for my XR500 router, it did a speedtest to determine the download/upload speed. That setup my quality of service uploads and downloads. But recent...
- Aug 03, 2020Click the 3 line option menu in the top left of the Anti-Bufferbloat panel and change your bandwidth speeds there to what you pay for/expect and it will then use the percentage of those new speeds.
edsi2fe_7hg
Aug 03, 2020Aspirant
Test again after you prefer upload much over download. If there is no option to prefer download-upload then it may prefer services, even download not sure.
Remember to disconnect as much devices connected to it as possible as well as services of the device that you think must be connected. If you feel then try fast.com too.
Part I don't understand is why QoS will not prefer upload when no download is running. QoS isn't a limitation, it only limits a less-preferred when it is demanded by a preffered service. So if some form of download is occuring it will naturally limit upload if you configure like it.
- Netduma-FraserAug 03, 2020NetDuma PartnerClick the 3 line option menu in the top left of the Anti-Bufferbloat panel and change your bandwidth speeds there to what you pay for/expect and it will then use the percentage of those new speeds.
