Painless_se
Aug 08, 2023Aspirant
XR500 intermittent dns timeout issue
So have had this problem for a while now and thought it was my ISP since they said they where working on some upgrade of their infrastructure but that work has been done for a while now. I have been ...
- Aug 10, 2023
Found a new problem too thanks to this forum if I start battlenet and there is a update it will cause this problem every time.
I have called my ISP to get a public IP instead of the CGNat one I am currently getting will take 1 to 5 days I have seen some other ppl on forums with the same ISP having this issue and this might solve the problem.
While checking the log to reply with it I saw I got a new IP in the log and its not a CGNat one and tried out battlenet and I can still load pages. Here is hoping the random timeouts problem is solved too.
Netduma-Fraser
Aug 08, 2023NetDuma Partner
It could be the Adblocker if you have that enabled, when disabling QoS how are you doing that exactly?
Painless_se
Dont think its the ad blocker since it works when I dont use the router. Still get the time outs on a browser without ad blocker.
I just disabled QoS in the router menu with the check box.
