Lashn
Sep 24, 2018Aspirant
XR500 Internet Connection Drop
I'm having so much problems with my new XR500 gaming router!
First of all it is not helping my internet connection and it is causing lag!
I have the router connected to my FRITZBOX modem via et...
Netduma-Fraser
Sep 24, 2018NetDuma Partner
Hi Lashn, it sounds like it is setup incorrectly as you would definitely see a benefit using the router.
HTTPS is not required, the interface is accessed locally. Only people connected to your network can access it. You are also not inputting any sensitive information.
Here is our knowledge base with guides to follow: http://support.netduma.com/en/support/solutions/16000056291 of course we're happy to answer any other questions you may have after following them.
