Ceagle
Aug 25, 2024Aspirant
Xr500 internet connection problems
Can't connect to the Internet on my xr500 pro gaming router. I also just got a new modem because ours blew and we set it up with the ISP but now my xr500 won't connect to the Internet. Please help. th...
Ceagle
If I'm correct the brand is spectrum and the model number is ET2251.
Aug 25, 2024Guru - Experienced User
Thats a Hitron brand.
Does the Internet LED on the XR router AMBER?
Power a power cycle or reboot of the XR router, the internet LED should change from AMBER to WHITE...
- CeagleAug 25, 2024AspirantThe light is amber I've tried power cycling it a couple times and that didn't work. it would just keep blinking white but it's not doing that anymore.
- CeagleAug 25, 2024AspirantSo I plugged the Internet back in and the power light is now blinking white but won't stay a steady white.
- FURRYe38Aug 25, 2024Guru - Experienced User
Any internet with the XR router now? WHITE led blinking should be ok. Just getting internet services.
- CeagleAug 25, 2024AspirantNo I still have no internet, but I think it's needs a firmware update but I'm not sure how to get the file on the computer to use tftp to update the firmware but I have no internet
