RossiDK
Dec 08, 2018Follower
XR500 internet issues
Hi I have just got a xr500 and installed it as directed to replace my default router from my fiber provider. All connected and working but unable to find the internet connection. I went through the...
Netduma_Jack
Dec 11, 2018NetDuma Partner
Try resetting your modem, then rebooting your XR500. Does it obtain an Internet connection after this?
If not, can you set your modem into bridge mode or modem mode and try again?
Finally, if that doesn't work, try factory resetting your XR500. Going through the initial setup will allow it to auto-detect your connection type
