Jaydos101
Feb 17, 2023Tutor
XR500 internet keeps cutting out daily
I own the Xr500 my internet keeps disconnecting daily for 4 months plus and idk what to do it cuts out on all devices wireless or wired, turning it off then on will fix it for a short while i've trie...
Jaydos101
Feb 18, 2023Tutor
Do you mean in LAN setup ?, It says address reservation add.edit,delete are you talking about that section ? thank you for your response
Netduma-Fraser
Feb 19, 2023NetDuma Partner
Yes that's right, so change the DHCP range first, then set the address reservations for devices.
- Jaydos101Feb 20, 2023Tutor
Im still not sure what you mean by change the DHCP range what setting do i change for that i only see IP address,Ip Subnet mask,RIP direction and starting IP and ending IP
- Netduma-FraserFeb 20, 2023NetDuma PartnerSo change the starting IP to .50 then you can assign the reserved IPs
