gt9484
Sep 30, 2019Tutor
XR500 INTERNET PROBLEMS
hi all, i have the XR500 and have had nothing but problems with it. drops raginging from 20/31 times in a day. I first thought this was my ISP and had multiple engineer visits trying to figure out i...
gt9484
Sep 30, 2019Tutor
Hi thanks for the reply. It's connected to a D7000 Netgear router set as a modem mode. I have had this issue since I first bought this XR500 but thought it was an ISP problem only to find it's actually on my hardware
Netduma_Alex
Sep 30, 2019NetDuma Partner
A D7000? Hm, okay you'd think that would be compatible given it's Netgear.
Could you take the D7000 out of Modem Mode and instead put the XR500 into the DMZ of the D7000? This has been known to stop drops.
- gt9484Sep 30, 2019TutorI will try this but it then has the confusing aspect of having two router and double NATS... This XR500 has done this when connected to the ISP router so I would have had this chance to work in the past... Is their a debugging firmware I can use to see if this has other issues I don't know about? Or can the image be deleted and re sent on the router to give it a proper fresh start? Seems like something isn't running like it should
- Netduma_AlexOct 01, 2019NetDuma Partner
Putting the XR500 into the DMZ of the upstream router should remove the double-nat issue.
It sounds like there might be a problem specific to your device. One thing I could suggest that often helps is to downgrade to the earliest available firmware and then upgrade straight to the latest one again.
Here's a link to the earliest available firmware: https://kb.netgear.com/000053241/XR500-Firmware-Version-2-0-0-28
- gt9484Oct 01, 2019TutorI feel robbed with this equipment as I was led to believe I had an ISP problem and spent the better part of a year dealing with it. Only to figure out it was the hardware. I feel like this router has problems on it, I never seem to get geo filters to work correctly and I have suffered continued drops for this entire time. If the router is malfunctioning is there not a debugging method to figure this out? Or wipe the device of all images and then re flash a new firmware. Downgrading and updating is something I have tried many time. As far as the geo filters I try and set a location yet I only ever get my local servers... I wanted to chose a more appropriate one for BO4 but I seem to just get randomly assigned even after setting geo filter.
