Stykee
Oct 15, 2018Guide
XR500 Internet speed Problem
So i bought mt XR500 router just a week ago, and i started to notice that am getting very slow internet speed compare to my ISP router?!?!
I dont know what the problem is i tried everything turnin...
- Oct 15, 2018Disable QoS completely from Anti-Bufferbloats options, do you receive full speed then? I'm assuming these are wired and not wireless speed tests?
Netduma-Fraser
Oct 15, 2018NetDuma Partner
- StykeeOct 15, 2018Guide
Yes their both wired connection. and yes ive already disable the Anti-bufferbloat, i set it to (Never).
Nvm you just solved my problem lol. What does Disabling the QoS do anyway?
Speed with QoS full disable.Fully Disabling QoS seem to fix my problem
- Netduma-FraserOct 15, 2018NetDuma PartnerIt completely disables QoS so it does not control your connection anymore, sometimes it can be required to gain full speeds. Send a screenshot of your normal QoS settings to be sure its not a settings issue.
