Stykee
Oct 15, 2018Guide
XR500 Internet speed Problem
So i bought mt XR500 router just a week ago, and i started to notice that am getting very slow internet speed compare to my ISP router?!?!
I dont know what the problem is i tried everything turnin...
- Oct 15, 2018Disable QoS completely from Anti-Bufferbloats options, do you receive full speed then? I'm assuming these are wired and not wireless speed tests?
Stykee
Oct 15, 2018Guide
Nvm you just solved my problem lol. What does Disabling the QoS do anyway?
Stykee
Oct 15, 2018Guide
Speed with QoS full disable.Fully Disabling QoS seem to fix my problem
- Netduma-FraserOct 15, 2018NetDuma PartnerIt completely disables QoS so it does not control your connection anymore, sometimes it can be required to gain full speeds. Send a screenshot of your normal QoS settings to be sure its not a settings issue.
