jteagles
Nov 21, 2018Tutor
XR500 Internet speed Problem
Hey guys,
Since Ive started using the XR500 my internet speed has nearly been cut in half.I was getting 75-80 mbps with the isp router but now Im getting around 45.Ive disabled Qos, Ive tried the m...
rakano77
Dec 11, 2018Aspirant
Hi - it sounds like you may have a problem elsewhere if you're getting just 33mbps into the modem. Are you able to switch your ISP modem back in and then connect your XR500 to that? You should hopefully be back to full speeds then.
- rakano77Dec 11, 2018Aspirant
Hi - it sounds like you may have a problem elsewhere if you're getting just 33mbps into the modem. Are you able to switch your ISP modem back in and then connect your XR500 to that? You should hopefully be back to full speeds then. DigitalOcean SiteGround iPage
