DylanDean1088
Feb 02, 2019Aspirant
XR500 Internet speed Problem
So today I bought the Nighthawk XR 500. I set it all up and thought I was good but the speeds on it were horrible. I was running faster speeds on my previous xfinity router. Ive seen these crazy spee...
Feb 03, 2019Guru - Experienced User
What FW is currently loaded?
What is the UP and Down speeds you should be seeing that you pay for?
Are you wired or wireless when speed testing? Wired is preferred for speed testing.
Netduma_Jack
Feb 05, 2019NetDuma Partner
What speeds do you get wired into your modem?
If you set Anti-Bufferbloat to 'Never' and rerun the test, do you get the same speeds?
