R4Z0R49
Apr 09, 2020Aspirant
XR500 Internet speed Problem
Hello, I'm having a bit of a problem with my internet speed. When i plug into our isp router (Router Mode & Moderm Mode) i get my full isp speed but when i connect to the xr500 my speed drops by abou...
Netduma-Fraser
Apr 09, 2020NetDuma Partner
What have you used to do these speed tests? Have you input your speeds correctly in the Anti-Bufferbloat option menu and when you disabled QoS did you do it from the same menu?
- R4Z0R49Apr 09, 2020Aspirant
Speedtest.net.
Antibuffer is disabled but set its self from factory reset (549down 37.18up).
QOS was disabled from the antibuffer section. (now get a big msg saying its disabled everytime i click on qos)- Netduma-FraserApr 09, 2020NetDuma PartnerDid it detect the correct speeds? If you do the setup wizard again in Settings does it detect the correct speeds again?
From what i can tell anytime i do a master reset which ive done alot over the last 4 months it manages to always pickup about the same numbers.
549/37.18 Auto setup speeds.
