ShinyCharz
Jan 27, 2022Aspirant
XR500 Internet Speeds / Latency (Connection)
Hello - I currently have 1 GIG internet thru my ISP. When I run the connection benchmark it will only go to 320 - 400 and that's it and give the internet speed a D. I can't figure out the issue on wh...
Netduma-Fraser
Jan 27, 2022NetDuma Partner
We're still improving the results shown by Benchmark so you can ignore that, as you're getting the expected speeds through Speedtest.net it's all working fine.
ShinyCharz
Would there be a reason why my ping is so high during online gaming - terrible latency.
- Netduma-FraserJan 27, 2022NetDuma PartnerWhat does the Geo-Filter say the ping is and what does the in game ping say?
- ShinyCharzFeb 21, 2022AspirantThe Geo Filter says ping is 23-28 and I’m getting 41, 42, 50, 60… etc. it’s awful
- Netduma-FraserFeb 22, 2022NetDuma PartnerOkay that's about right then, they add processing delay to the in game calculation between 10-30ms usually. Still quite a respectable ping really but try forcing different servers, even if the Geo ping is a bit higher the overall ping shown in game may be lower if the server isn't under much load.
