ShinyCharz
Jan 27, 2022Aspirant
XR500 Internet Speeds / Latency (Connection)
Hello - I currently have 1 GIG internet thru my ISP. When I run the connection benchmark it will only go to 320 - 400 and that's it and give the internet speed a D. I can't figure out the issue on wh...
ShinyCharz
Feb 21, 2022Aspirant
The Geo Filter says ping is 23-28 and I’m getting 41, 42, 50, 60… etc. it’s awful
Netduma-Fraser
Feb 21, 2022NetDuma Partner
Okay that's about right then, they add processing delay to the in game calculation between 10-30ms usually. Still quite a respectable ping really but try forcing different servers, even if the Geo ping is a bit higher the overall ping shown in game may be lower if the server isn't under much load.
