ArnaudM
Apr 16, 2018Tutor
XR500 internet time setup and SSH access
Hi experts. Couple of questions for you. I recently bought the XR500 as I got seduced by the DumaOS screens. I previsouly had a Netgear R7000 which I had flashed with DD-WRT Kongo. Liked it a lot but...
Netduma-Fraser
Apr 17, 2018NetDuma Partner
Do let us know your suggestions, we love customer feedback!
- Settings > Content Filtering > Schedule.
- Yes it is blocked
- I don't believe there is a way to limit it to HTTPS.
- Yes it is blocked
- ArnaudMApr 17, 2018Tutor
Thanks! Sorry for missing the way to set the router time, to be honest I was not expecting this one under Content Filtering (would rather see this in Setup or Advanced Settings maybe?).
Limiting to HTTPS would be a neat feature for a next release (only allow TCP:443 e.g.) as well as SSH. If I were to ask for features, I would suggest allowing the user to upload additional device pictures (like PNG format, certain size etc) to represent more devices (or get them from the community), the ability to import/export list of static IP's or static routes, access to cron, ability to poll SNMP (an advanced Traffic Meter) and uploading to a Syslog server. These are good features from DD-WRT I've been using a lot :)
Thanks again !
- Netduma-FraserApr 17, 2018NetDuma PartnerGreat thanks a lot for the suggestions! A lot of those would be covered by Netgears settings so not much that we personally can implement. It may be worth opening a ticket with them with your suggestions so they can pass it on to their dev team.
- JasonNApr 19, 2018NETGEAR Employee Retired
Hi ArnaudM,
Thank you for your suggestions. I will be forwarding these ideas to my internal team to review for consideration. :]
- Jason N
