wait_i-m_low
Oct 22, 2018Guide
xr500 ip fragmentation ps4
Hello i have an ip fragmentation Problem with the new Duma Os.
I use the xr 500 and already test my MTU. MTU max is 1472 but i still get the IP fragmentation message when the PS4 hits the NAT test ...
wait_i-m_low
Oct 22, 2018Guide
Yes it’s a public ipv4
37.
When I set it to auto games are mostly not playable cause of heavy lags
37.
Oct 22, 2018Guru - Experienced User
Be sure DMZ is not being used while the modem is bridged.
You might do a full factory reset on the XR. Power Off the modem for 1 minute then back on. Then walk thru the setup wizard on the XR router and let it set things up again. Run some speed tests to ensure your speeds are good. The XR should auto detect speeds as it's setting up as well. After it's set up, look at the QoS settings and see if the speeds detected by the router are good.
