wait_i-m_low
Oct 22, 2018Guide
xr500 ip fragmentation ps4
Hello i have an ip fragmentation Problem with the new Duma Os.
I use the xr 500 and already test my MTU. MTU max is 1472 but i still get the IP fragmentation message when the PS4 hits the NAT test ...
wait_i-m_low
Oct 23, 2018Guide
It looks like that there is an issue with the Netgear routers.
I made the walkthrough with factory reset and all the other things. Had a phone call with my isp. Everything is perfect from their side.
But I still get the warning from the Ps4 and gaming is not so much fun right now.
Oct 23, 2018Guru - Experienced User
- Netduma-FraserOct 23, 2018NetDuma PartnerSent you a PM to try on a different firmware
- wait_i-m_lowOct 31, 2018Guide
Hi #Netduma- Fraser,
the Firmware that you send me really improves my internet connection.
everything is now faster, its not good but better.
The Ip Fragmentation Problem is not solved.
Still the same Message, doesn´t matter how i set the MTU in the PS4 or in the router.
Best regards,
Ingo
- Netduma-FraserOct 31, 2018NetDuma PartnerDo you notice if it affects your connection at all? As its a beta firmware it'll likely just be based off the latest public version. Hopefully won't be too much longer for the next version so if you could check on that one when released. MTU is the most common cause for it. Do you have a lot of devices connected to the router? Having a look online at others with the issue on different routers that is a potential cause.
