packetdrop
Nov 20, 2018Star
XR500 ipv4 vs ipv6 speed differences
I feel bad putting this here without knowing more but I recently got a new config from my ISP for a 900/35mbs line (from 400/35). Direct line tests for around 500 (on speedtest.net) and ISP still thi...
- Nov 21, 2018
Just wanted to follow up saying that I managed to resolve the issue by rebooting both the cable modem and the router in sequence leaving the MAC at the PCs. I strongly suspect that the XR500 router was not at fault for the issue but rather that for some reason the ISP/modem capped ipv4 traffic until the reboot.
I am now running with QoS and ipv6 fully enabled without any issues and get equivalent speed tests over both ipv4 and ipv6.
packetdrop
Nov 20, 2018Star
Not using PPPoE.
Netduma_Jack
Nov 20, 2018NetDuma Partner
Ok, try disabling IPv6 and see if that improves things.
- packetdropNov 20, 2018Star
See message 3 for results with ipv6 disabled, still degraded performance.
- Netduma_JackNov 20, 2018NetDuma Partner
Ah thanks - hadn't realised there were two replies.
Just to clarify, can you answer these questions please:
- What speeds do you get wired into the modem?
- What speeds wired into XR500 (~100mbps right?)
- What speeds wireless into XR500?
I'm wondering if there's an issue with your ethernet cable between the XR500 and either your PC or the modem. So answers to 1 and 3 will help narrow that down
Hate - you misunderstand. Generally people should be fine with IPv6, but when someone is having a an unusual issue, it's always wise to shut down possible problem areas until you figure out where the problem is.
I get around 500-600mbs direct wire PC into modem. I get 80-120 wired through XR500 on the same PC using ipv4 speed tests. I get 80-120 wireless on 5ghz band 3 feet from router using an iPad ipv4 speed test. I get 500+mbs on the PC through XR500 using ipv6 speed tests. I get 500+mbs @ 5GHz 3 feet using ipad ipv6.
So wired vs wireless has no noticable effect at close range. All these are uneffected by QoS completely disabled or on but on set to never with share excess enabled. Turning ipv6 off makes all speed tests cap out at 120mbs.
Router is using the PCs MAC in case that matters.
