ghostoflight7
Dec 23, 2018Aspirant
xr500 ipv6 and speed issues
my wifi runs terribly now, i started using cat5e and its only gotten worse. my xbox wont even work being hardwired with cat5e and i dont know what i should do.. if theres any settings i need to make ...
Dec 25, 2018Guru - Experienced User
What FW is currently loaded?
What WPA security modes are you using?
