JonSnowKnowsNad
Feb 05, 2020Apprentice
XR500 IPV6 disabled and dropping frames when streaming
Im on the latest firmware and when i disable ipv6 im dropping frames continuously while streaming, but when i enable ipv6 im no longer able to see my network monitor so what should i do?
Netduma-Fraser
Feb 05, 2020NetDuma Partner
How did you have Traffic Prioritization setup initially before you disabled it? You may just need to fine tune it instead to prioritize specifically the game if it was prioritizing part of the stream. It could cause jitter/spikes without it depending on your bandwidth speeds/the network queue at the time.
JonSnowKnowsNad
i left traffic prioritzation on default settings. which is DumaOS classified games. i didnt touch it or play with it. i just disabled it and no more dropped frames.
- Netduma-FraserFeb 05, 2020NetDuma PartnerAre you attempting to stream from a PC or a console? If you're happy with leaving it disabled that is fine, otherwise I would recommend using one of the available services to prioritize or use specific game ports for what you are playing.
- JonSnowKnowsNadFeb 05, 2020Apprentice
im using my pc to stream and console to game. if i wanna prioritize my cod mw game on console would i have to go to advanced because theres no simple option
- Netduma-FraserFeb 05, 2020NetDuma PartnerOkay DumaOS Classified Games may have been picking up the stream then, keep that disabled then add your console with the console service and then try please.
