steven316
Feb 26, 2022Tutor
xr500 ipv6
hi i am new to this i cant get ipv6 to work i used the 06tunnel it showes but it dosnt show as ipv6 on mmy x box it is bt 500meg cxan anyone help mr on how to get this to work or do i nee...
- Mar 03, 2022Have you enabled the option to use DHCP for LAN devices? If not try that
Feb 26, 2022Guru - Experienced User
what modem/gateway do you have?
What firmware is on the router?
Are those the correct IPv6 settings for your isp?
You also might get better help in the proper forum for the pro-gaming routers. the DumaOS guys are very helpful on there.
steven316
Mar 08, 2022Tutor
it is the xr500 nighthawk but think i have it working now thanks for the help
- FURRYe38Mar 08, 2022Guru - Experienced User
Enjoy. 📡
