steven316
Feb 26, 2022Tutor
xr500 ipv6
hi i am new to this i cant get ipv6 to work i used the 06tunnel it showes but it dosnt show as ipv6 on mmy x box it is bt 500meg cxan anyone help mr on how to get this to work or do i nee...
- Mar 03, 2022Have you enabled the option to use DHCP for LAN devices? If not try that
steven316
Mar 08, 2022Tutor
it is the xr500 nighthawk but think i have it working now thanks for the help
Mar 08, 2022Guru - Experienced User
Enjoy. 📡
