Pastuch's avatar
Pastuch
Follower
Sep 03, 2020
XR500 is a nightmare
1. I can't use smartconnect, if I do the router drops connection to my wireless devices constantly.
2. I can't access discord while using the geofilter because it hangs on RTC connecting. As soon as I turn off the geo filtering and put the router in spectator mode I am able to connect to discord again.
3. Not one aspect of this router has worked as intended, I really want to try the 3.0 OS but I'm waiting on the beta signup list.
1 Reply
  • I believe we are helping you on the Netduma forum and I've just replied to you there.
