Cujoma
Oct 20, 2018Guide
Xr500. Is it possible to get full speed on ps4
Hey guys. Just bought this router but I have a question. I have high speed internet 100/10. I’m assuming with bloatware and qos on there is no possible way to acheive this speeds on my ps4. I have no ...
Cujoma
Oct 21, 2018Guide
Thanks for the reply. I have everything you stated done. Anti buffer bloat to 70 on download and upload and set to high priority traffic. The only thing i didnt do was change my flower, which is default set to split the bandwidth everywhere. Everything seems to work fine it was just the issue with the slow lan speed test on my ps4.
Netduma-Fraser
Oct 21, 2018NetDuma Partner
It really shouldn't affect anything you do on the console. Gaming doesn't require much bandwidth so you're absolutely fine there and your downloads should still be as fast
- CujomaOct 21, 2018Guide
Yeah it is just slow speed test. If i hardwire to the modem, or use a different router the speed test on the ps4 is closer to my 100/10. It is usually somewhere around 85/8. With this router and the option on we spoke about the best i can get on a speed test is around 35/3. Ive tried about 20 speed tests on there. When im on the ps4, all my other devices get around 70 down and 7 up which im assuming is because the anit buffer bloat is set to 70% on a 100/10 connection. Which is fine. I just dont understand why i cant see those speeds on the ps4 through this router. As i said the other router is fine (asus ac86u) and directly to the modem is fine
- Netduma-FraserOct 21, 2018NetDuma PartnerCan't really explain why that is but as it's not causing any issues I'd just keep an eye on it for now
