b333fy
Aug 26, 2018Follower
XR500 is it suitable for my needs?
Hi Everyone,
Excuse my lack of knowledge but I am looking for a Router to do the following and I "think" the XR500 would be suitable for my requirements.
1) Throttle Bandwidth per device. So for e....
Naxterra
Aug 28, 2018Apprentice
Logging is not working properly at the moment. Also web site blocking doesn't work on HTTPS sites. I don't think you can set schedules for device access to internet.
- Netduma-FraserAug 29, 2018NetDuma Partner1. Yes
2. Not specific device scheduling but can disable Internet completely at specified times or just simply block the devices manually.
3. Not aware of the logging not working but it should do that.
