Jesse94
Jul 30, 2019Guide
XR500 is not connecting with my NBN FTTC NCD
Hi Everyone, I just got today my XR500 NightHawk, I have a NBN FTTC connection so i have th NCD box to make me able to use it, before i bought the XR500 i informed my self by asking the seller if t...
Netduma-Fraser
Jul 30, 2019NetDuma Partner
As well as the above try accessing the interface using the IP instead which would likely be either 192.168.1.1 or 10.0.0.1 and see if you can finish the setup that way.
Jesse94
Jul 30, 2019Guide
I dont know how to finish the setup the 2nd light from the left is orange wont go white
- Jesse94Jul 30, 2019GuideBefore I bought this I was told that I dont need a modem only the Nbn NCD box I'm hoping I havent been fooled.
- FURRYe38Jul 31, 2019Guru - Experienced User
You need a modem in front of the XR router. The router depends on a ethernet connection that uses DHCP or static IP addressing from the modem to get it's connection.
