Jesse94
Jul 30, 2019Guide
XR500 is not connecting with my NBN FTTC NCD
Hi Everyone, I just got today my XR500 NightHawk, I have a NBN FTTC connection so i have th NCD box to make me able to use it, before i bought the XR500 i informed my self by asking the seller if t...
Netduma-Fraser
Jul 31, 2019NetDuma Partner
Was the modem/router provided by your ISP? If so then it's not surprising that they may require you to have it connected. Add it back to your setup and if possible put it in modem mode or put the XR500 in its DMZ and then connect everything to the XR500.
Jesse94
Aug 01, 2019Guide
Yeah i managed to make it work but the only option that i had was to connect the router through the IInet Modem + the NBN NCD without being attached to the IINET Modem it wont work.
- Netduma-FraserAug 01, 2019NetDuma PartnerOkay thats fine, everything should work just fine with that setup!
