fatboy526
Dec 02, 2020Aspirant
XR500 issue: "R-app is not loaded yet. Please try again in a minute
Hi .i bought this router about 1 week ago,and after setting it up it says "R-app is not loaded yet. Please try again in a minute.I have read all the forums and tried updating the soft ware to facto...
djsly2k
Jan 02, 2021Tutor
Im also having the same problems.
When mine happens I cannot open the QOS page or network monitor and also wifi devices that are not already connected will not join.
Rebooting the router fixes it for 2-3 days and then it happens again,
Considering sending this back.
I have the 2.3.2.66 fw.
- Netduma-FraserJan 02, 2021NetDuma PartnerIn System Information on the Rapp panel options change it to 5 then reboot the router and see if that helps please.
- djsly2kJan 03, 2021Tutor
Rebooting the router always fixes it, temporarily.
The trouble is, that after a few days they then become unresponsive leaving me no choice but to reboot the router to regain functionality.
QOS page fails to load as does network monitoring and geo filtering, I wait long enough and get the error about R-app is not loaded.
Reboot of the router is fine short term but its becoming more of an inconvenience.
- Netduma-FraserJan 03, 2021NetDuma PartnerIf you change the retry amount then reboot that will help as it will try to load the Rapps more before throwing an error.
