fatboy526
Dec 02, 2020Aspirant
XR500 issue: "R-app is not loaded yet. Please try again in a minute
Hi .i bought this router about 1 week ago,and after setting it up it says "R-app is not loaded yet. Please try again in a minute.I have read all the forums and tried updating the soft ware to facto...
Netduma-Fraser
Jan 02, 2021NetDuma Partner
In System Information on the Rapp panel options change it to 5 then reboot the router and see if that helps please.
djsly2k
Jan 03, 2021Tutor
Rebooting the router always fixes it, temporarily.
The trouble is, that after a few days they then become unresponsive leaving me no choice but to reboot the router to regain functionality.
QOS page fails to load as does network monitoring and geo filtering, I wait long enough and get the error about R-app is not loaded.
Reboot of the router is fine short term but its becoming more of an inconvenience.
- Netduma-FraserJan 03, 2021NetDuma PartnerIf you change the retry amount then reboot that will help as it will try to load the Rapps more before throwing an error.
- djsly2kJan 14, 2021Tutor
Doesn't work for me, here is a clip of what im having to deal with every other day https://www.dropbox.com/s/8w9gqu9ydzx8afk/2021-01-14%2019-35-21.flv?dl=0
Reebooting the router constantly is getting really frustrating.
- Netduma-FraserJan 14, 2021NetDuma PartnerI'd suggest upgrading to the beta and then doing a factory reset as we do have fixes in there that should help with this issue https://community.netgear.com/t5/Nighthawk-Pro-Gaming-DumaOS-3-0/bd-p/en-home-beta-npg-duma
