SteG
Sep 25, 2019Aspirant
Xr500 Issue
Not sure where to go with this, or if my XR500 is still working but. Last night I had major issues with my router and my connection, at first I thought it was my internet connection then I worked ou...
Sep 25, 2019Guru - Experienced User
Is Smart Connect Enabled or disable?
Set 20/40Mhz Coexistence to 40Mhz only
SteG
Not sure how I can do any of that, if I can't connect to the routers setting.
It's a bt open reach modem.
- Netduma_AlexSep 25, 2019NetDuma PartnerWhat IP address is your computer being given?
