IITC
Sep 09, 2018Tutor
XR500 Issues with Upnp/Port Triggering Fixed?
Hi
As seen here in Simj Clip from March it seems that there r problems with those 3 Options. Are they fixed with the newest Firmware or are the still Present ?
"Standard Features That are n...
- Sep 11, 2018
Ports not displaying correctly in UPnP is a known bug, and we're investigating it as we speak. Hopefully a fix for that issue should be available soon.
Ping Assist will be on its way soon - there were a couple of delays and other features which needed to take priority, but Ping Assist will be one of many new features to come :)
Netduma_Jack
Sep 10, 2018NetDuma Partner
We can't say when a fix for each issue will be released but we're aware of all of these issues and we're working closely with Netgear on potential solutions to them. DumaOS will be very well supported long into the future, so these issues won't be around for long unlike other routers.
Ping Assist will also be coming soon - again though, saying when precisely it is coming would be a mistake since other obstacles could prevent themselves. We'll make sure to keep everyone in the loop though. Whenever a new feature or version is released you will know about it! :)
