IITC
Sep 09, 2018Tutor
XR500 Issues with Upnp/Port Triggering Fixed?
Hi
As seen here in Simj Clip from March it seems that there r problems with those 3 Options. Are they fixed with the newest Firmware or are the still Present ?
"Standard Features That are n...
- Sep 11, 2018
Ports not displaying correctly in UPnP is a known bug, and we're investigating it as we speak. Hopefully a fix for that issue should be available soon.
Ping Assist will be on its way soon - there were a couple of delays and other features which needed to take priority, but Ping Assist will be one of many new features to come :)
IITC
Sep 10, 2018Tutor
Thx 4 response.
I played yesterday around and found out that while i am playing the Ports for PS4 and COD r open, but after i shut down the Console the "Open" Ports" r missing in the UPnP section.
Today i will check in with my Xbox too.
I am on the newest FW, btw.
Somewhere in a diffrent forum post i read that the "Ping Assist" for the Development DumaOS has not even started !? It was promised Weeks after the initial XR500 release, and now we r near the End of the year, i hope it lands this Year on the Devices, hopefully before the COD Season starts ;)
Netduma_Jack
Sep 11, 2018NetDuma Partner
- IITCSep 11, 2018Tutor
