Jake1400
Sep 03, 2020Aspirant
xr500 issues
Hello, I recently bought the xr500 and have been having some issues with NAT and wired connection. When I first set it up and tried playing xbox, I was given the double NAT. I fixed this by switching ...
Netduma-Fraser
Sep 03, 2020NetDuma Partner
What is your exact physical setup? Setting NAT to Open in WAN settings will help with this as well.
- Jake1400Sep 03, 2020AspirantI have a modem that the router is plugged into. Then I have the Netgear PL1000 plugged into an outlet and into the router. My other PL1000 is plugged into an outlet near my Xbox and I have an Ethernet core running from that to the xbox. And how do I set the NAT to open in WAN settings?
- Netduma-FraserSep 04, 2020NetDuma PartnerWhat is the modem model? Go to Settings > WAN Setup and you can change it there.
- Jake1400Sep 04, 2020AspirantThe modem was provided by my ISP. How do do I find out the model? And will changing the WAN settings fix the unavailable NAT on my Xbox when I’m wired?
