aeroluis88
Jun 16, 2020Aspirant
XR500 Ivacy Setup
Hi guys! I kindly request your support if there is any of you using Ivacy VPN could guide me on how to connect as VPN Hybrid. Regards
- Jun 16, 2020
aeroluis88Exact instcution:
Hi, seems that mod only can give guides :-)
1. download and unpack: https://ivacy.s3.amazonaws.com/support/OpenVPN-Configs.rar
2. choose any .ovpn file and put "#" sign before lines:
ca ca.crt
tls-auth Wdc.key 13. add key-direction 1 at the end of file
4. paste at end of file
<ca>
---- content of ca.crt
</ca>
<tls-auth>
---- content of wdc.key
</tls-auth>
Netduma_Alex
Jun 16, 2020NetDuma Partner
I can see from their support site that these are the OpenVPN files you want: https://ivacy.s3.amazonaws.com/support/OpenVPN-Configs.rar
aeroluis88
Hi,
I already download .ovpn files setup my username and password but connection states failed.
I had no issues with Vyprvpn, but I can't find the way for ivacy.
- Netduma-FraserJun 16, 2020NetDuma PartnerYou need to combine the .crt file with the .ovpn file for the server you want to use. The .ovpn will be at the top and then under that type <ca> then paste the .crt file and after that type </ca> so it should look something like this:
client
dev tun
etc
etc
etc
<ca>
contents of .crt file
</ca>
Then paste that into the advanced section on Hybrid VPN and enter your user/pass and it should allow you to connect.- aeroluis88Jun 16, 2020Aspirant
Hi to all of you!
Here is the info I'm pasting on configuration box field. Server location: United States Washington - UDP. Connection failed. Please see Log at the bottom.
client
dev tun
remote uswdc2-ovpn-udp.dns2use.com 53
proto udp
nobind
persist-key
persist-tun
tls-auth Wdc.key 1
ca ca.crt
cipher AES-256-CBC
comp-lzo
verb 1
mute 20
float
route-method exe
route-delay 2
auth-user-pass
auth-retry interact
explicit-exit-notify 2
ifconfig-nowarn
auth-nocache<ca>
-----BEGIN CERTIFICATE-----
MIIE6DCCA9CgAwIBAgIJAMjXFoeo5uSlMA0GCSqGSIb3DQEBCwUAMIGoMQswCQYD
VQQGEwJISzEQMA4GA1UECBMHQ2VudHJhbDELMAkGA1UEBxMCSEsxGDAWBgNVBAoT
D1NlY3VyZS1TZXJ2ZXJDQTELMAkGA1UECxMCSVQxGDAWBgNVBAMTD1NlY3VyZS1T
ZXJ2ZXJDQTEYMBYGA1UEKRMPU2VjdXJlLVNlcnZlckNBMR8wHQYJKoZIhvcNAQkB
FhBtYWlsQGhvc3QuZG9tYWluMB4XDTE2MDExNTE1MzQwOVoXDTI2MDExMjE1MzQw
OVowgagxCzAJBgNVBAYTAkhLMRAwDgYDVQQIEwdDZW50cmFsMQswCQYDVQQHEwJI
SzEYMBYGA1UEChMPU2VjdXJlLVNlcnZlckNBMQswCQYDVQQLEwJJVDEYMBYGA1UE
AxMPU2VjdXJlLVNlcnZlckNBMRgwFgYDVQQpEw9TZWN1cmUtU2VydmVyQ0ExHzAd
BgkqhkiG9w0BCQEWEG1haWxAaG9zdC5kb21haW4wggEiMA0GCSqGSIb3DQEBAQUA
A4IBDwAwggEKAoIBAQDluufhyLlyvXzPUL16kAWAdivl1roQv3QHbuRshyKacf/1
Er1JqEbtW3Mx9Fvr/u27qU2W8lQI6DaJhU2BfijPe/KHkib55mvHzIVvoexxya26
nk79F2c+d9PnuuMdThWQO3El5a/i2AASnM7T7piIBT2WRZW2i8RbfJaTT7G7LP7O
pMKIV1qyBg/cWoO7cIWQW4jmzqrNryIkF0AzStLN1DxvnQZwgXBGv0CwuAkfQuNS
Lu0PQgPp0PhdukNZFllv5D29IhPr0Z+kwPtrAgPQo+lHlOBHBMUpDT4XChTPeAvM
aUSBsqmonAE8UUHEabWrqYN/kWNHCNkYXMkiVmK1AgMBAAGjggERMIIBDTAdBgNV
HQ4EFgQU456ijsFrYnzHBShLAPpOUqQ+Z2cwgd0GA1UdIwSB1TCB0oAU456ijsFr
YnzHBShLAPpOUqQ+Z2ehga6kgaswgagxCzAJBgNVBAYTAkhLMRAwDgYDVQQIEwdD
ZW50cmFsMQswCQYDVQQHEwJISzEYMBYGA1UEChMPU2VjdXJlLVNlcnZlckNBMQsw
CQYDVQQLEwJJVDEYMBYGA1UEAxMPU2VjdXJlLVNlcnZlckNBMRgwFgYDVQQpEw9T
ZWN1cmUtU2VydmVyQ0ExHzAdBgkqhkiG9w0BCQEWEG1haWxAaG9zdC5kb21haW6C
CQDI1xaHqObkpTAMBgNVHRMEBTADAQH/MA0GCSqGSIb3DQEBCwUAA4IBAQCvga2H
MwOtUxWH/inL2qk24KX2pxLg939JNhqoyNrUpbDHag5xPQYXUmUpKrNJZ0z+o/Zn
NUPHydTSXE7Z7E45J0GDN5E7g4pakndKnDLSjp03NgGsCGW+cXnz6UBPM5FStFvG
dDeModeSUyoS9fjk+mYROvmiy5EiVDP91sKGcPLR7Ym0M7zl2aaqV7bb98HmMoBO
xpeZQinof67nKrCsgz/xjktWFgcmPl4/PQSsmqQD0fTtWxGuRX+FzwvF2OCMCAJg
p1RqJNlk2g50/kBIoJVPPCfjDFeDU5zGaWGSQ9+z1L6/z7VXdjUiHL0ouOcHwbiS
4ZjTr9nMn6WdAHU2
-----END CERTIFICATE-----
</ca>
Logs
Tue Jun 16 17:35:40 2020 OpenVPN 2.4.3 arm-openwrt-linux-gnu [SSL (OpenSSL)] [LZO] [LZ4] [EPOLL] [MH/PKTINFO] [AEAD] built on Jul 16 2019
Tue Jun 16 17:35:40 2020 library versions: OpenSSL 1.0.2n 7 Dec 2017, LZO 2.06
Tue Jun 16 17:35:40 2020 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Jun 16 17:35:40 2020 NOTE: the current --script-security setting may allow this configuration to call user-defined scripts
Tue Jun 16 17:35:40 2020 Cannot open file key file 'Wdc.key': No such file or directory (errno=2)
Tue Jun 16 17:35:40 2020 Exiting due to fatal error
