connorcoolbeans
Dec 11, 2021Tutor
XR500 Keeps disconnecting
Randomly throughout the day my XR500 router randomly disconnects itself stopping me from accessing internet/wifi. The strange part is none of the LED's on the router change colour. It can be quickly ...
Dec 11, 2021Guru - Experienced User
what modem/gateway is it connected to?
Is it roughly the same time apart when its disconnecting? just curious what your isp has your lease times set for.
Do wired devices drop at the same time
- connorcoolbeansDec 11, 2021Tutor
It is connected to the virgin media superhub 3 which I belive is manafactured by Arris model noTG2492LG-VM
I will start taking notes as to when the dropouts occur. Only other wired device I have connected other than my PC is my Bridge for my phillips hue smart lighting.
- plemansDec 11, 2021Guru - Experienced User
Have you put the XR500's IP address into the superhub's DMZ?
How would I do this? I tried having a look but dont think this is possible whilst the superhub is in modem only mode?
