Omar12349
Apr 27, 2020Aspirant
XR500 keeps giving my PS4 LAN Cable not connected
Keeps saying lan cable not connected at the exact time everyday someone told me it has something to do with the DHCP Lease or something but still nothing, I reserve the lan I reseted the whole router ...
Omar12349
Apr 28, 2020Aspirant
Yea happens to all devices it’s really annoying
Netduma-Fraser
Apr 28, 2020NetDuma Partner
Go to Settings > Monitoring > Connection Status, does DHCP Lease obtained/expires show once a day?
- Omar12349Apr 28, 2020AspirantYes it does
- Netduma-FraserApr 28, 2020NetDuma PartnerGo to Internet Setup and switch from Dynamic to Static and then apply, if you don't get a connection right away then reboot. See if it happens again after that.
- Omar12349Apr 29, 2020AspirantIt stopped happening but also there’s another problem now my speeds went from 250 mbps to 60 on PS4 and won’t go above 60 mbps when I switch back to dynamic speeds go back to 250 mbps I thought having a expensive router wouldn’t have problems like this :/
