Omar12349
Apr 27, 2020Aspirant
XR500 keeps giving my PS4 LAN Cable not connected
Keeps saying lan cable not connected at the exact time everyday someone told me it has something to do with the DHCP Lease or something but still nothing, I reserve the lan I reseted the whole router ...
Netduma-Fraser
Apr 28, 2020NetDuma Partner
Go to Internet Setup and switch from Dynamic to Static and then apply, if you don't get a connection right away then reboot. See if it happens again after that.
Omar12349
Apr 29, 2020Aspirant
It stopped happening but also there’s another problem now my speeds went from 250 mbps to 60 on PS4 and won’t go above 60 mbps when I switch back to dynamic speeds go back to 250 mbps I thought having a expensive router wouldn’t have problems like this :/
- Netduma-FraserApr 30, 2020NetDuma PartnerThat doesn't really make any sense because the settings aren't any different in that scenario. Have you rebooted the PS4 since you made the change? If not do that and see what the speeds are. Are the speeds as expected on a wired PC test?
