gamestoned's avatar
gamestoned
XR500 lag on IPTV
Hello everyone,
I'm facing an add issue on my brand new XR500. Configured IPTV on my Samsung MU8000 using SmartIPTV app but while swiping channels it takes anywhere between 10-15 secs & most of the time connection failed.
This happens only to IPTV my streams like Netflix, xbox, Prime all work fine. Just like my previous router. Only the connection failing on IPTV channels.
Paul
  • Is it possible there's something wrong with the app? The fact other channels work fine suggests this could be the reason.
    If you connect your TV to your router or another modem, does the issue continue?
    • gamestoned's avatar
      gamestoned
      I just tried that and plugged back my old router (Asus DSL-N66U). No issues. Channels swap less than a second between each other. So definitely there is something wrong on the XR500 that's causing this behavior.
      • Netduma-Fraser's avatar
        Netduma-Fraser
        NetDuma Partner
        Disable QoS in Anti-Bufferbloat options, does that resolve the issue?
